As soon as the “NEW” 1906’s came out, I started using them. They have hidden knuckle springs, and look better. I still have most of the two fleets with 820/920’s, and won’t replace them except when one breaks, or causes trouble. They all “Play” together very well.
I understand the 1906’s now come in rust colour under the 1906B number. They all use the same draft gear box. (black and Rust)
A year or so ago (Maybe earlier) Kadee started shipping couplers, “G” and “#1” with plastic threading screws, instead of their previous nuts and bolts. I like the nuts and bolts better, and have a great supply of them, and longer ones that I use in some cases. When installing on plastic, I seldom use any nuts. I just drill the holes with a drill in a pin vice, just the correct size, that the screws (Bolts) self tap , and don’t need nuts.
Some cars need to have a bit of cutting, in order to get the couplers at the correct height. If done well, the car will look great. All shims I need are cut from sheet Styrene.Most plastic cars are made from Styrene, so they can be mounted on the car with lacquer thinner. If the Styrene is painted, it does help to scrape the paint clear.
DO NOT glue the couple draft gear boxes to the car, or glue the draft gear boxes together. If you do, and ever need to replace the coupler; it will cause difficulty doing what would be a simple replacement.
I would NEVER recommend using offset couplers. First; they are not prototypical, and second; they tend to look like heck. Thirdly; they tend to want to bend slightly under a heavy load, putting pressure on the draft gear, and mounting arrangement.
I have seen many many so called experts going out of their way to find the hardest way to body mount Kadee couplers, and always stare in wonderment, asking myself WHY…I guess they get pleasure from it, or something…!!
I don’t consider myself any sort of expert, but I have converted way more than 1500 cars of just about every make (Not European or brass models), using primarily 820’s/920’s/1906’s and 830’s/906’s. Very seldom ever needing any other style. Some were a challenge, I’ll admit…!! And I’ve see first hand, other peoples’ trials; using everything from little bits of Balsa wood, to scraps of paper as shims. Some of them were converted by people that claimed that converting to body mounts wouldn’t work for them. I wonder why…??..!
I do conversions for others, and have never had a complaint, but tomorrow is another day. A fellow dropped off 60 cars to be converted to 906’s a month or so ago. That is one of my Winter projects, to keep me out of trouble. !!! (I had already done 40 or more for him earlier…)
