I’ve been using my RS-3 as a test mule for a while.
A new (actually the first) sound file for my QSI titan has been released, the new “ET”, where a program runs in the decoder to actually simulate the locomotive, like a plane simulator.
Sounds fancy and goofy at the same time, but the bottom line is another step up in realism, along with higher bit rate sounds, etc.
Since I had previously learned the “secret” of the 21 screws requiring removal to take off the cab and hoods, and having destroyed the circuit board board a couple of times, I decided to “fix everything”
Hah!
Well first off when a 2 axle motor block Aristo loco seems to be awfully sensitive to dirty track, chances you the wheels and track are not the problem.
One thing that can cause problems is a derailment that causes a short between the 2 wheels of a motor block (not too often), or between the wheels of the front truck and the back truck (very typical on a switch).
When this happens you can easily damage something, and it’s often the traces on the main board that the trucks are wired to, notice the top traces on this board:
This is the second time I burned a trace, I actually burned the lower one first, did a repair and then burned the top one. You can see if these traces go, you are only picking up from one truck, thus with fewer power pickups, it will seem to be requiring cleaner track.
One solution is to put a circuit breaker on each of the track pickup leads. Why on each one? so as to protect from shorts in any combination side to side or front to rear.
In the picture below, I have added a Polyswitch to all 4 track pickup leads. For those who are not familar with these, they are a self-resetting circuit breaker, solid state (actually when too much current is drawn, they heat up and liquify inside and the liquid has a very low conductivity)
This will help avoid a very common problem. Note well: Many Aristo locos have these Polyswitches in them, but normally they are (in my opinion) in the wrong location, often protecting from a shorted motor (rare), or overcurrent on the “mu plugs”, which are only used when coupling loco power externally.
