I recently bought a LGB engine and found out today why it was so cheap. It seems the motor is acting up.
It runs fine then when I stop it it won’t spin again unless I tap on it or start the worm gear moving. The motor looks clean and the contacts that I am attaching the power leads to are clean which tells me that something inside is loose or worn. The engine it came out of has very little wear on the wheels or skates.
What do you think and what can I do to get this going? It has a shaft and gear at both ends and came out of a “shorty” 0-4-0
