A brief layout update
Matt, how are you approaching potential future tunnel access for maintenance and (god forbid) derailment issues?
Cuz,
Dad would be proud!
Actually, I can envision a tear in the corner of his eye!!
If tunnels are planned, I’d build access in from the start: lift-out scenery or removable panels at each end and at mid-run, plus enough clearance to reach in and rerail. Avoid any tunnel section longer than you can comfortably reach through an opening.
You can easily reach in from either side of the tunnel. The top section has screws holding panels together. I’m going to cover that with pond liner. Worst case scenerio, I’d have to dig out a few 5 gallon buckets of dirt to get to the screws.
Thanks cuz!
Sure do miss that dude.
