After deciding that I wanted to build some correct 1/29 track, I figured my first major step was to build a turnout. The area I’m modeling has #9 and #11 turnouts and 110-90lb rail. Big for the garden, but small for the real thing. The 110-90lb rail works out to be code 215, and code 172 (if I can find any, or decide to use code 205) So after copying off a set of NP Standard Plans for the #9 Turnout with 100lb rail I’ve got everything I need.
From point to the tip of the frog it’s 72’ scale feet. I started by gluing tie plates to the rail sections in order to establish the correct tie spacing without having to worry about the ties moving, or having stringers underneath. I also cut the web, and head of the rail at the correct lengths to represent 39’ sections. This way I’ve will retain as much as I can of the full 6’ lengths but have 39’ sections.
Then I started spiking the two straight legs of the turnout. Picking a spot that was between the points and the frog, and didn’t require any special tieplates.
Filling in with what I can before moving on to the complicated stuff.
Next I started building the frog. I can’t really lay the diverging route until I get the frog completely built.
This required a lot of filing, checking against the plan, filing and more filing. I now have the point assembly of the frog glued together and am waiting for the JB Weld to dry before I can fine tune the point. Meanwhile I’ve been working on adding details to the wing rails. No pictures yet. I drill and glued in Atlas track nails on one side of the wing rail to represent the bolt heads. On the opposite side I’m going to use either a NBW detail, or build something out of styrene. I’ve also got 1 point filed down to the basic shape, but that too will require more final filing to fit the stock rail. I can’t file anymore on the points until I get the rest of the turnout built. Craig
