This week I had the opportunity to install an RCS battery R/C system in a Tootle Engineering 7/8n2 critter. There is plenty of room under the bonnet/hood for the batteries and R/C control system. I chose to use 4 x 1500 mah Li-Ion cells wired in series to give 14.8 volts. I made up a styrene sheet on which I mounted the battery pack. Above that I made some more styrene supports for the ECL-3r ESC & decoder assembly.
The resulting “brick” is 65 mm x 55 mm x 60 mm tall. The owner had me fit the regular Hobby King 6 channel RX which simply plugs in upside down on the decoder part. No servo leads needed.
The block ends up looking like this:
Then I added the 4 way cable between the decoder and the ESC.
If you want to use an Spektrum AR500 RX it looks like this:
The assembly is connected by pre-made plugs and sockets and simply drops into the bonnet/hood space.
The red plug shown poking up is for the charger. It does not matter where the antenna is located. All wrapped up and ready to go.
The TX will give a size comparison. The critter is quite big and runs superbly.
