7/8 Critter Build
A few weeks ago I trekked up to meet Bruce Bates of Birdwater fame. While there I acquired a few of his past kit offerings. I’ve decided to begin with the critter. I was told all the kit was built for use with the Aristo-Critter block. I didn’t have one of those, so I used a 45tonner block.
I had to adjust the frame a little to get the motor in.
I think the future 7/8 ‘stuff’ will initially run on batteries and switches.
Here’s the critter with the ‘Toby’ I built way back to Fn3 Scale…course it don’t look bad at all with the 7/8" critter…wonder if my measurements were wrong after all?
I need to get some wood filler and begin that process. To cover the wood, I sprayed a little gray primer.
while shopping wood filler, I’m going to try to locate the ugliest green/yellow/orange to finish coat it with. I’m also going to add a styrene skirt to cover the holes behind the counterweights.
Back later
looking good so far Cale. Be careful running unfinished models, they tend to stay unfinished and running around the layout (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-surprised.gif)I think it took me 4 years to finish a Porter once it was operational.
I am really beginning to like little locos
That is a great little engine. I still prefere these over the larger engines. Lots of fun to run.
Nice! Really runs quiet too.
Gotta luv those critters. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Very nicely done. Looks right at home on your nice layout.
Doc Tom
