So I got bored, realized I had two 4-6-0s sitting around with dead drivetrains…and this resulted
It has a Connie gearbox in it, attached to a stainless steel rear axle with nylon insulators in the wheel hubs. I cut down the smokebox to the first set of rivets, and then had to trim down the smokebox front (the smokebox plastic gets thicker near the back, so the smokebox front wouldn’t go in). Trimmed the stock connecting rods down and made something that sort of works (I have a bit of binding, but I’m working on that). I still have to trim the piston rods down. The front axle is a stock Bachmann axle, but when I tried to trim the frame to mount the bushings, it snapped off…so I CA’d in some sheetmetal that so far is working very well. Still to do: Trim pilot shorter, new aluminum front truck(shorter wheelbase), different headlight (probably), new stack (coal burner), trim the cab interior out, and finish a tender for it (it no longer has power pickups, so I need a battery/RC tender). What think? Any suggestions?
He’s into big stuff. It’s nice, definitely keeping it, just not my thing. I’ll take my K-27 any day!
May even be something from Morocco in French Colonial days. How about this Aussie beastie
