While having lunch about a week ago with a friend, Dave that works at the KU Med (IT dept) where Kristi was, he asked about using my CNC mill to make some PC boards. Between the two of us talking, I sketched up a idea for a machine that could be used for 3D printing and by changing the head and pulling the heatbed off and installing a Dremel, it could be used as a small router. Then after some more thinking, I could also make a 40 watt laser head and a vacuum table to have a laser…
With all I have going with Kristi and in the shop now, and will be going back to work as soon as Kristi is able to be alone, I wouldn’t have time to work on it for a few months. I offered Dave to come up and use the shop and he could build a prototype to see how well this idea will work. Within the next week or two he will be starting on the frame work and will be gathering all the rest of the electronics and materials that will be needed. The prototype will have a table size of about 8" X 16" and 12" high. Then once he (we) get it running and printing as good as we can, the next one will have a table of 12" X 26" for laser and router work and print size of 8" X 24" X 12" high.
These machines will have a mini computer onboard with a display and SD card reader. They will not have to have to be linked to a computer in anyway to run. Once all the software is downloaded and it is configured and calibrated (this might have to be changed between doing the different heads), it’ll run on G-code off off of the SD card.
I’ll keep this updated as it progresses.
Rodney
