Kristi is doing very well and we hope that she will be back to 100% in six months or so. Between taking care of her and work, I haven’t worked in the shop much with trains. I watched a lot of TV and worked on learning how to draw in 3D with sketchup while keeping a eye on Kristi.
My printers are built from plans off the net and are made out of aluminum. They are more of a industrial design and I think are better that most you find in the market. There is a couple of places that sells the basic frame with motors like the ones we have built for around $700. Then you still need to add the electronics and extruder for another $300 or so. Back when I started building the printers, I machined enough parts to build 15 printers. With my youngest son’s help, we have built 7 with a build area of 8"x8"x8" and 3 with a build area of 12"x12’X12". I also machine all the parts and build my extruders. I’m working on a design of a 12"x36"x12" printer now. It’ll be a lot different than the ones we have built so far.
Chuck, I’ve read that a extruder mounted on a router is WAY too slow. Most printers run about 300mm a second or faster. My original idea of using the same platform for a laser, router and printer ran into these problems. I have about all the material to build a 3’x6’ router table and a 80 watt laser with a bed of 2’x4’. I hope to have them done in a year or so. Just not enough home time to do everything I want to do. I like to see some pic’s of your router build. Are you going to use a water cooled spindle or just a regular router. I’m getting the 6000 to 24000 RPM water cooled for around $275.
Rodney
