Am beginning my first ever Crest Revolution and Phoenix P8 install in my LS Bachmann Heisler. Have spent several hours on-line finding and printing any references to same. Factory, “manuals,” for these are good, but blending the wiring for the two is a bit vague and I want to get it right. No plug-and-play here. In all the parts for this kit, there is a 3300uf capacitor on a little one-inch square print board, has leads and a tiny connector that will plug into main board. However, I seem to recall when I got all this I was told this cap was not needed. Is this right?
I intend to remove all the Bachmann wiring, track voltage pick-up plungers, etc. Then wire motor leads directly from truck/motor blocks. I suppose replace headlight and rear light with 5mm LED’s. I have the little smoke board to be able to continue it’s function. Firebox flicker seems to be too involved to retain, (being part of the Bachmann PWB)
All electronics need to go in the locomotive’s oil/water bunker.
If anyone has done this for the Heisler, I’d sure like to hear feedback. Right now, it’s the capacitor that puzzles me as there is no reference to it in manuals. Comments appreciated.
Dennis
