Bob/Del… I run the Li-ion in 100+ degree heat at 5000 feet altitude with hot sun beating on the battery cars and tenders. Temperature in the battery cars can get up to 165 degrees… I have had the REVOLUTION receivers overheat but never an Li-ion battery overheat and shut down…
I take the roof off to allow air to circulate and that solves the problem… I just installed fans in the car that causes the most problems… No results of the tests yet…
Just my findings…
And I hadn’t even considered altitude … Probably just don’t worry about it. Batteries probably aren’t the limiting factor. Given the conditions of Arizona vs: Florida … I’ll take Arizona every time. New thread?
