Fred Mills said:
Devon;
I hate to say this, BUT…if you have to ask those questions about ground wires, grounding, black vs White, size of wire…
I strongly advise that you consider purchasing a book, usually available at builders’ supply shops, that explain the wiring you are considering, along with local electrical codes…buy it and you will have the answers to most of your questions.
Failing this…hire an electrition to either do the job of pulling the actual wire, and doing the hook-up, or advise you on how to do the job,…because you are giving the impression, by your questions, that you are about to fail code, or electrocute yourself and possibly others.
You are really on your own with the questions you ask…you have too much information, but not enough knowledge/experience to do the job yourself…SAFELY. This is beyond just low voltage, garden lighting…the guys here can try to help, but you need someone on the ground, at your place to advise you…BE VERY CARE FULL…
Fred Mills
Well I really only asked two questions and one of them I already pretty much knew the answer to. I pretty much knew I would run individual coated wire in the conduit. The main question I really didn’t know was the ground issue. The other question was circuit amps but that was mearly for suggestion not because I didn’t know.
I knew which wire did what. I also know which size to run for each amp circuit. I am not a complete novice when it comes to electrical. As I said I have wired an large addition to my house complete with Bathroom GFCI and arc fault protection for the bedrooms. All witha permit and all inspected and all to code. In fact I was complemented on the quality of work. I installed my own 200AMP panel and 240VAC 70AMP sub panel in the garage. So really guys I am not a stranger to electrical and to wire a couple of 20AMP GFCI circuits is not a monumental task.
I will head the advice and run the ground back to the panel. That was the only area I wasn’t sure on.
I also appreciate the warnings and caution. Since no one really knows what I know, its better to offer the warnings than to not and have me light myself up. So I am not at all put off about the warnings it is appreciated.
