Does anyone have a source for 12 volt headlight bulbs, LEDs, etc for LGB locos?
Thanx,
jb
12?
They have 5 and 18, isn’t it?
I use 14V, hot-glue them to the sleeve, pitch the sockets.
If you want 12v, just get some Miniatronics GOR bulbs at the hobby shop and hot-glue them in.
OK, 14V.
Can I get them from you?
jb
Yup.
LGB uses 3 different bulb voltages.
The 18 volt bulb is the screw in version (Bayonet base) and has a yellow tint. I use solvent to get the yellow tint off and make these clear.
The plug in bulbs are 5 and 24 volts. The flat top bulbs are 5 volts, the round tops are 24 volts.
While we are at it, the track powered smoke units with yellow/brown leads are 16-18 volts, black/white are 5-6 volts and the yellow/yellow are 24 volts.
