I generally model in 1:24 scale on my indoor railroad but I’ve been tinkering with some 1:20 scale stuff after building a “critter” for a friend who then changed to 1:29 scale. I used a power truck from a Bachmann 1:20 44 tonner to make this critter. (I’ve since used the other power truck to make a 1:29 scale boxcab for my friend). Right now I’ve got it running on simple battery power- a 5 cell NiMh pack and an on/off switch. The water car is the latest build, made from wood in the shop and a can. The wheels are plastic with turned down flanges and the hose is a piece of wire with some paper and plastic bits for the nozzle. It scales out to 12’ long. The last car is small gondola like tender that I used as a battery car for a small Porter. I’ve since built a new tender for the Porter so this little guy is just tagging along to make up the train. I’m thinking about changing the label on the water car to weed control as I’m really not sure what a railroad would use a water car with a hose for. I plan on making up a couple more little guys to tow around and maybe make a small switching layout to tinker on. Dave Hope this picture loads.
Hmm, can’t seem to get it load in the message but the link works.
There are a couple of problems with the filename that keep it from displaying as an image. [code]
