So I have decided to shelf the 2-6-0 for awhile. I am frustrated with it. I will take it to the RPM meet as is, its for completed or models in progress well this is in progress. But for know I need to give it a rest.
The 2-6-0 was going to be the loco I was going to take to Dave Goodsen’s for his op session with Steve. Then when that was no longer I was going to take my Geep, until Steve informed me it was Bachmann couplers and I was going to use a transition car but Sat he told me I would need to push and pull so a transition car was a no go. That means I need a new option.
So that little Bachmann side tank Porter I have with the new gear was a prime candidate. It will be the Sinsley Mountain Logging & Mining Co. #2 “Logan” and will be used for switching in town and as the prime mover taking stuff to and from the mine and mill until the #3 “Darcy” 0-4-2 2-4-0 Garratt can be built. I bought this loco in a box of junk for $20.00. I was gong to make this a 2-4-0 but the front pilot deck I put on it precludes it. So it will stay an 0-4-0. But I have made some mods. The most noticeable is the missing side tanks. They are replaced with side boards. It was also missing a pilot deck so I used the one from the B-mann lil hauler that is the little logger I am building. I needed a new support that attach the arms that hold the connecting rods (not sure what they are really called) and the slide so that all got fabbed in brass. The tender is a New Bright from the same box. It has been gutted and will hold the R/C and battery equipment from the 2-6-0. I used the plug and socket from the New Bright, I actually like the plug and socket. I made a draw bar and then body mounted a B-Mann coupler to the rear. Once I install the RC equipment then it will be ready to run. I will paint it up but I won’t be detailing it until later after the logger is done. This will give me a second running locomotive to play with.
This was one days work. I think I made good progress.
