I purchased an LG&B LGB boxcar from Dash.com for $23 recently. I liked the look of the car, and for that price I just couldn’t resist.
They have been having a lot of LGB and USA cars for auction for less then $30 lately. I need to stay away from that site, but I digress. In another thread I explained how I have been updating my heavier narrow gauge stock to ball bearing journals, so that my Moguls can haul a nice string of them up my 2.58% grade.
http://largescalecentral.com/forums/topic/24202/ball-bearing-journal-inserts
When it came time to upgrade this car, it became clear that this car had been run so much it was nearly worn out. My first clue were the plastic wheels it came with.
It appears they have quite a few miles on them. I can not see how the thing even ran with wheels like that. But putting metal wheels and ball bearings in the truck side-frames didn’t completely fix the car. The car also wobbled badly, because the bolster kingpins were also badly worn.
I also discovered, while working on the car, that it originally came with some kind of sound system. The floor has been partly cut out, and there is the symbol for sound on the car doors. What sound it came with, I do not know.
I had to fix the kingpins so the car would quit wobbling so bad. So I took some Evergreen 1/4 tubing, the package didn’t say if that was ID or OD, but I suspect its 1/4 inch OD, and slipped a piece onto the kingpin. I had to trim the ridge off of the top of the pin to get it slide on. Then I glued it in place with some Tennex, and trimmed it to length when the glue had dried.
The tubing had fit properly into the truck kingpin hole before I put it onto the kingpin, but since it was such a tight press fit, it had stretched a bit and the truck would not fit over the tubing anymore. So I sanded the tubing until the truck would fit. I want the truck to swivel freely, but I don’t want it to be loose on the pin. So it was a matter of sanding a little, test fitting and sanding some more, until I got the fit I wanted. Then I fixed the other kingpin, it was just as bad.
