STEVE… for you…
With temps on the 20th of February at 75 degrees, we thought we would do some work at Okawville…
First up, was to install an inherited H-Beam as the switch lead… (thanks Ric)…
The Goal was to keep it elevated, so the water drainage off the hill would flow under it… As the retaining wall at Okawville was complete, we needed to build a new wall at the left side of the picture below, to hold the west end of the H-beam…
The new wall built today can be seen in the center of the picture. The H-beam also is the switch lead for the elevator at Okawville, and the End of the line…
The below view is taken at the end of the line, looking back thru Okawville…
All the track has been laid… Settling is required, then minor work to level the track area…
As you can see, the grounds supervisor to the right of the tracks, is not interested in the completed work…
Plants will be planted at the top of the retaining wall on the left, and also in the small wall area at the end of line…
