Yesterday I had my first exposure to a material we don’t use often. The brand we buy is called Ultra Board but I think it is also marketed as Gatorplast. This is a composite material composed of two very thin (.010 perhaps) polystyrene sheets laminated to a foam core. Being smooth styrene, attaching details should be easy.
We put a scrap sheet in our CNC router and cut some shapes. Our technique needs work, but it shows potential of being able to route out door and window openings for buildings. I didn’t try it yet, but we might be able to route very shallow scribe lines for siding. I will not be offering this service as machine time is very costly and it is a slow process.
I have no idea how weather proof the stuff is. I brought home a small piece of black and placed it outdoors where it will stay through the winter to see if the styrene de-laminates and how the foam holds up.
Cost is reasonable. 4’x8’x3/16" sheets of white run about $35 and black $38.
Yes it did look good!
