Added a piece of plexiglass to fill in a gap. Also to fasten the under frame work to it.
This arch piece needed removed to allow clearance for the cross head assembly made from a piece a plexiglass.
Arch being removed…
All gone…Now the frame can sit under the boiler with plenty of room…
New cylinder chest cut. The red ones as seen before did not fit correctly so I had to redo those…
chest added to the front pilot mount… these were cut down in the center. Needed to remove a 1/4 inch from the centre so it would sit flush to the boiler sides…
So I have the underframe completed and the crosshead done and mounted to it. The slots cut for the drivers and the guides for the piston rod. I used a Bachmann piston guide and rotated it 90 degrees to get the look of the General’s locomotive guides. They may need to be narrowed a bit tho. I took a 4-6-0 drive rod and cut it down to fit and it works really well after being tested. However I need to make a set or side rods and drivers to replace these. the 1860’s were square and not tapered as the ones I used to test this all out.
I really want to replace the guides with ones made from brass. I ran out so I will need to pick up some more this weekend. The MPC model part is on the top right. I am wanting to try to replicate this design…
So this is where I am at now… The locomotive runs really smooth with the current drive rod that is from the Bachmann. Just doesnt look right. I will add some more photos later this weekend… As I have been working on this I thought of “MIK” whom most of us knew from here.I think he would be pleased that most of this Locomotive build is being built from scrap stuff…
…To Be Continued…
