I figured you guys would like to see and hear the whole sorry saga of this railtruck. The quest for a power truck was covered in a separate thread, and I decided to make my own so here goes.
The rear truck has to be set up to drive like the Bachmann railtruck axle - the motor and driveshaft come from the front just like a real truck. The present truck is an archbar with solid wheels, and I figured spoked wheels would look better. I also decided to use my skew bevels that I got from eBay (Tradeship, old slot car parts.)
So I started accumulating bits and pieces. I found a pair of spoked Liliput (Bachmann Europe) wheels and a pair of Bachmann small wheels in my parts box. The axle for the latter is 3mm which is 0.118", somewhere between 3/32 and 1/8th (0.125"). The bevels say 3/32 shaft on the package.
I found some 1/8" brass tube, and I took a wheel off the spoked and the small wheel pairs. Turned out the Liliput used a sholdered axle, so the 3mm axle off the small wheels would have to work. I found a 3mm drill and prepared to open up the 3/32" (0.093") shaft in the large bevel, only to find it was 1/8" ! As you can see above, it fits the shaft, and the difference in size is only 0.007 (7 thou.) However, the set screw is only on one side, so the bevel won’t be centered if I don’t shim it.
Next is to find some 3/32 steel rod to use as the drive shaft across the axles. I’ll probably need a universal or 2 that fit the same shaft. And some 1/8" inside bore tube to use on the axle to support the drive shaft. I plan on soldering a “crossbox” as Grandt Line calls them. There was one on my Railcar that I just fixed, which gave me the idea.
