Today our club is having a work day in my shop to construct, “Engine Carriers”. The basic carrier sits on top of your track and allows for your locomotive to run out onto the track without having to man handle it. The bottom runners are aluminum angle attached to a wooden frame. The carriers also protect the locomotive during transportation.
I will be taking lots of pictures today showing the different materials that we use and the assembly process along with a completed carrier for those interested in coping our design.
Chuck
Chuck, Here are a couple pics if the engine carriers I make. I use 1/2"x 1/8" flat aluminum for rails. The rails are milled to a taper on one end and the masonite floor is cut away underneath the same end about 6". The ends of the carrier are resting in slots and can be removed easily. One end has a 2x2 block attached to it. When this end is removed and placed underneath the carrier, between the carrier and the track, at the opposite end, it creates a nice slope with the tapered ends of the carrier rails resting right on the track rails. It sound like yours are similar.
