Thanks, Dan.
I set up and external MOSFET and optoisolator to power the heater directly from the battery, and everything is working now.
I’m curious why the supplies for the heater and lights would need to be separated. I assume the low voltage outputs are just regulated versions of the V+ terminal? Since I’m using CL2N3s, the supply voltage is irrelevant for my lights.
18V at 100% duty cycle did prove to be too much for the smoke unit, though. Moments after I took this video, it burst into flames. I’ll have to reduce the duty cycle.
