Here’s my idea Devon that I have thought of.
Use a small standard computer plug (3 or 4 pin) and mount the male end into the end plate of the locomotives
Take the female ends and wire them to the brass glad hands ( soldered together). Female pin ->glad hands> female ends.
Make a set of dummy plugs
Female plus to glad hands.
When you want to run two units together, you plug the computer pins in to the male connections. Loos right with glad hands, etc. When you need to disconnect the two locomotives, you still can.
Here’s the problem… The glad hands for the MU lines are about O scale. You need 2 o scale sized glad hands, 1 1/32 sized glad hand for the Main Res. Line and then 1 1/29 glad hand for the brake pipe. Plus the MU electrical hose.
