Craig Townsend said:
ECP brakes are a new braking system that is not in wide spread use. ECP brakes allow for faster sets, and releases as an electrical signal is sent to each rail car to set/release the brakes, instead of using air to send the signals. ECP is another expensive beta technology that is being tested on a limited number of equipment.
If I remember correctly CP Rail uses them on two of their coal unit trains. They did some test run(s) assembling two of the 127 car trains into one lash up. Then proceeded over Rogers Pass, Eagle Pass and Notch Hill to Chase. Work well as far as it went, but trains of that length are a bit of a problem as far as sidings go.
BTW using DPU on long trains will also help the brake response, provided it is set-up correctly.
