John Bouck said:
Bill, You sound like you have quite a bit of experience with track, switches, etc. So forgive me and others on this board for assuming you were a rookie. TOC is TOC, blunt, to the point, and knows more about lokies than myself and most people here. You have to know him to love him. :) :)Anyway:
It isn’t your track, or all of your rolling stock will have some kind of problem.
Put all ten lokies on the track, one at a time. Run them one direction, then the other.
Turn them around and repeat the same procedure.
Remove all the “good” ones.
How many bad ones are there? One, two?
If they all do it, then it is:
You are prolly the unluckiest dude in the world to buy 10 bad lokies; or there is something else.
The one or two–run them, one at a time, backwards, forwards, pick them up and reverse them and do the same. The lead truck becomes the trailing truck, etc.
Is it the lead truck that derails all the time. If so, the motor drive is a little off and climbing the rail. It may have a different RPM than it’s sisters in the block. Just slightly. Faster or slower.
It is definitely the swivel pilot. Could be tweaked a little to one side. Could be off-level because of the connecting bar, Could be anything!
Remove the offending swivel truck and replace it with one of your good ones off of another lokie.
Test again. It should not derail.
Put the good one back in it’s original truck and send the offenders to USA. (Not the whole lokie–just the motor block) and tell them to replace it!
That’s about all you can do.As Tony stated, no large scale manufacturer has perfected the three axle truck except LGB. That’s why I stick with small two axle dismals.
Bachman, Delton couldn’t even produce a three wheel steam truck without blinding a driver or two–(Even though some real steamers had blind center drivers). The aforementioned, Bach, etc, couldn’t even get their blind driver to ride on the rail-head!
LGB has flanged drivers in all their products except the RhB Crok! Mogul, Mike, Mallets–all flanged!
But I digress…jb
TOG
Thanks John I will go over all 10 with a fine tooth comb and thanks for the tips too. As of now I don’t know how many of the 10 that I own have problems but I will check them all that is for sure. Plus I don’t know what is the main problem with the truck until I check each one out by checking things we have gone over thru our discussions. Once again thanks!
