Well Guys since I started this Thread off by asking a kinda dumb question as I see it now, I wanted to show you what came out of all your comments about the transistion from one parallel track to another. Since I am running some 1:20.3 locomotives that need a Min 4ft radius to run, I decided to build the transistion using #5 turnouts which kinda equate to using (2) 22.5 Degree turnouts. I printed out the #5 turnout drawings and taped them togther to form the transistion and the cut all the cose 332 Aluminum rail on Saturday. I had already cut the 1/4" sintra and glues the hand cut ceder ties to it based on the ties placement on the turnout drawings.
I started laying the Rail on Staurday and spent a couple hours on Sunday ad then installed the Guard Rails tonight to finish it off. The throw bars are Fibreglas PCB boards with coper on one side. I drilled 1/16" holes in the web of the closure rails and then used 1/4" long Brass tacks to go through the closer rails and then through the PCB throw bar and then the tacks were soldered to the copper cladding. This firmly attaches the throw bar to the rails.
As you can see from the photos, it came out pretty good. I have another one of these to build with the transistion in the opposite direction. The ties are cut from a ceder fence board and are cut to 1/4 x 3/8 x 3 3/4" The ties are glued down with the 3/8" side to the sintra. This allows the 1/2" spikes to go through the ties and into the sintra which helps hold them in place.
This whole assembly will then be screwed down to the elevated deck of my Yard area. More on how I built the elevated yard at a later date. All of the track on the yard is done the same as this Transistion section, with the ties glued to 1/4" Sintra.
This transistion section is 44 1/2" long x 10 1/4" wide.
Dan Stuettgen
Colorado & Rio Grande Southern
http://danshobbies.webstarts.com/index.html
