Town Water Towers
Andy, Great idea! I’m slowly making one of these in 1/29th scale myself. Below are pics of one I made years ago in ‘O’ scale for my basement layout. Being detail oriented (read that as anal about accuracy) I can tell you I measured several. They vary in size and shape. The ‘Squished’ top one is an ‘ellipsoidal’ water tank. The round tank I got up close to was called a Horton Watersphere. As for dimensions, what I can tell you is the vertical support tube should be 6 feet in diameter (that’s 2.5" in 1/29th). On my ‘O’ scale tower I used a 1.5" OD acrylic tube. For my 1/29th WT I am planning on using a 2" PVC pipe (the higher pressure schedule so the OD is almost 2.5"). On the watersphere I made in ‘O’ scale the sphere should have been 28 feet in diameter (that would have been 7" but I could only find a 6" diameter ball so that’s what I used) So your choice of a 12" ball is perfect for this type watertower. I’m making mine 12" also! The bases of watertowers vary quite a bit so whatever you do will probably be close to a prototype somewhere. My watertower is named Wilbur after my dad’s friend who had a great American Flyer layout in his basement and was the person who kept my brother and I interested in model railroading
(http://ogaugerr.infopop.cc/groupee_files/photo_albums/8/6/9/8691094284/81710151_62F7B3D8C302734A56ACE7A65131D740.JPG)
(http://ogaugerr.infopop.cc/groupee_files/photo_albums/8/6/9/8691094284/72710151_0B93B193DFCAA5277E7510A440ED3108.JPG)
Keep up the good work! Brian B.
Andy,
One more suggestion/idea. You may want to mix up a good quantity of Bondo and fill the red funnel and shove it up to your globe. When it cures the funnel will pop right off and you’ll have a very workable/paintable surface. The material the funnel in made out of is probably too slippery to paint and have it stay. That’s the perfect property for demolding it from bondo though.
Brian
Brian, thanks, and that tower looks great…
Brian, that O scale tower looks great! I especially like the details on the base.
Andy,
Thanks, I’m looking forward to seeing yours when completed.
Ray,
Thanks, I really went crazy making it accurate, including the hold-down bolts and brackets. That water tower is currently on my brothers ‘O’ scale layout so I can go visit her every once in a while.
Brian
