I should have put this post over here, instead of in my layout, so, NOW it IS here. (And there, too.
Well…having a layout underneath the oak trees is nice for shade in the summer (although it doesn’t do much to reduce the humidity
Unfortunately, between the acorns and the branches that fall - it is tough for my buildings and structures.
I had a branch fall on my turn-table bridge so it’s time to take it in for repairs…
I will need to resolder the railing as well as replace a few of the boards. Not a big deal, but it will take some work.
I was a bit optimistic when I posted that. Upon further examination, I discovered a lot of dry rot. A smart person would have rebuilt it, but I’ve never been accused of being very smart.
So, just a few repairs were done instead of a rebuild.
I found I still had some cedar about the same thickness of the existing planks and replace a number of boards. I tried to address some of the dry rot with Plastic Wood and MagicSculpt. We’ll see if any of that actually holds up.
I also attempt to be really lazy on the repair of the hand rails - attempting to avoid soldering them I tried using glue as well as Magic Sculpt and Epoxy. When those attempts failed I ended up resoldering the handrails and actually soldered a thin brass strip across the top to hold it to the vertical pieces.
I repainted the railing and applied multiple coats of boiled linseed oil. Hopefully that will work better than the Behr’s I originally used.
After the “repairs”, it DOES look a bit better.
I probably should have replaced more of the planking than I did…
More junk has accumulated since I took this in a few months back.
Everything needs cleanup, but it’s still a bit damp from Friday’s rain…
Nothing bit me when I was cleaning out the turntable pit; I’m rather happy about that.
So, for something built in 2006, it doesn’t look TOO bad…
