Please turn your heads now as this may be another “frivolous post”.
Late last year, I read Michael Glavin’s statement on another thread: “These 1.5A charge rates I’m noting are NOT correct for larger batteries and or cells in series-parallel battery configuration, such as 5400/6800mAh batteries. The manufacturer recommended charge rate for ONE cell is 1.625 for the 3400mAh Sanyo/Panasonics @ maximum time interval of 4 hours. The Tenergy TLP3000 as mentioned above is adequate for a 4-cell battery only." I then contacted the following reputable dealers, manufacturer, installer, and another very knowledgable gentleman on this board (who will remain nameless). These people have all been in business for a long time, and I asked them the same question regarding compatibility between my battery packs and my charger.
RLD Hobbies – Robbie Dascotte, owner
Me: I have a Tenergy 1.5 Amp Universal Smart Charger. It charges 14.8V Li-ion battery packs. Will that work OK charging your 14.8V HJE Li-ion batteries? Are the HJE batteries as good of quality as the CVP-recommended (Sanyo/Panasonic/LG) battery packs?
Robbie: Your charger will be fine. I sell a lot of them. My HJE batteries are the exact same as AirWire batteries. They are made by the same company.
https://www.rldhobbies.com/hje-4sc.aspx
Reindeer Pass Railroad - Mike Kidman, owner
Me: I would like to know your opinion on the preferable charger for charging battery packs. I just bought this battery pack from you:
http://www.reindeerpass.com/airwire-14-8v-6800-mah-liion-battery.aspx
Mike: When selecting a charger you need to match the battery chemistry(Li-Ion), battery voltage (14.8V), match the polarity correctly, and charge at a low rate. 1 -1.5 amps. We sell hundreds of the two we have listed on our site, Tenergy $32.99 and HJE $26.99, and have had almost no problems with them.
http://www.reindeerpass.com/tenergy-smart-charger-for-li-ion.aspx
CVP Products (Airwire) - Keith Gutierrez, owner
Me: Just to clarify, can I use the Tenergy TLP3000 1.5A charger to charge my new Airwire 14.8V 6800 MaH battery packs without damaging the batteries? Specification/description in quotes as follows: “Intelligent charger designed for all types of 14.8V (4 cells) Li-Ion Battery packs including Polymer Li-Ion and Cylindrical Li-Ion”.
Keith: The internet comments to the contrary are incorrect. The TLP3000 is a smart charger rated at 1.5A and can charge 14.8V lithium ion batteries. Click on the link below to go to the charger manufacturer’s website and read about this charger.
http://www.tenergy.com/01206-01
Garden Railroad Supply Company – Bob Ferguson, owner (15+ years doing train battery conversions, mostly for BAGRS club members).
Me: I’m having second thoughts about whether I purchased the correct charger from you when I asked you to do my first battery installation.
Bob: The CVP (Airwire) battery charger is the same Tenergy battery charger that I provide. Keith Guiterrez, the owner of CVP, is also the electronics designer and engineer who determined the correct charger to use with their battery packs. This is the charger that Tenergy recommended when I attended my original sales meeting at Tenergy to set up the proper products that I offer on my website. Your battery pack has 8 cells. It is actually two 4-cell packs wired in parallel to create the amperage advertised. Each 4-cell pack is wired in series to add the voltage of each cell (3.7v) together to arrive at 14.8 volts and 3400mAh. Adding the two 4-cell packs together in parallel gives you the 6800 mAh rating. The battery charger sees the battery pack as a 4-cell pack rated at 6800 mAh. You have the correct charger.
http://www.gardenrrsupply.com/charger-battery-li-ion-tlp-3000/
