mike dorsch said:
Glad to see the CN unit in its new home Rooster. Looks good ! That engine as well as my BNSF SD 70 made a clunking noise from day one. It didn’t seem to affect its performance so I didn’t do anything about it .
All good Mike and thanks …the front axle had missing teeth on the axle gear. I just flopped the axle so it makes no contact with the worm gear (free floating it ). Essentially making it a 5 axle gear driven unit but it works great! Only issues the crew has noticed is when the toilet flushes the lights go dim. But a turbo plunger has been installed in the cab so all is working fine.
BTW …noted your body mounted 830’s which work well but I ended up doing sill mounted Kadees on the other unit I have and very happy with that install.
Good stuff and still thinking about getting out the fillet knife but not sure.
(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)
This post has been edited by : Rooster
