Ric Golding said:Yes Ric, we know. It's all a matter of how much you started with that allows you to consider certain industrial strength substances. BTW the handicap race started in the 60s, at least if I'm to believe some of the LSCers ("If you remember the 60s, you weren't there") and since I wasn't there - as in "that loony crowd" - I'm quite happy to use M-E-K for the intended purpose. ;) :)
You guys do know you are in the brain cell sacrificing relay races with some of this stuff, right?
Ahhh,
Nothin link the scent of a freshly glued and painted model…
timmyd said:
Yeah... I guess! The back fo the Testors Model Master says:NOTICE: Intentional misues by deliberately concentrating and inhaling the contents may be harmful or fatal.
WARNING: This product contains a chemical known ot the State of California to cause cancer and birth defect or other reproductive harm.
CAUTION: Keep away from heat an dflame. Contains Xylene. Use only with adequate eventilation. If swallowed, call physician immediatly. Keep applicator covered when not in use. KEEP OUT OF REACH OF CHILDREN.
Guys, I think TimmyD is in trouble - one of the first signs of the snuff impacting your gell being is that effects your speling.
Tim - get outside and breath large quantities of flesh air.
Oh my God, its contagious through a confuser scleen.
John Bouck said:jb, yer just gettin' old and slow. :lol:Steve Featherkile said:Steve, I tried it as weld, but it dried to damn fast to do a good job. Haven't tried laq thinner. But I love Ambroid and Tanax. What ever blows your dress, I mean kilt up........................:) :)
Acetone does a good job of welding styrene together, too.
I once had a small bottle of acetone that I would drop scrap styrene into.
The idea was to make a thicker glue from the melted styrene.
It worked a little, but the styrene goop was too thick.
I gotta get the recipe fine tuned.
Ric Golding said:You must be using too much glue for it to crystalize. A good super glue joint is tight, no gaps. Then it works best. In fact I have actually stretched styrene pieces trying to pull a joint apart. But with the following caveat. The joint was tight, and had at least 1/8 square inches of surface contact. A joint with gaps will snap apart easily and you will see crystals of super glue residue. So, if you're not planing on using it to fill bad joints, it is fast and effective and I have ship models that I have built that are 10 years old with super glued joints that are still holding up just fine.Richard Kapuaala said:Richard, do you get long lasting joints with Super Glue? I find it crystalizing and letting go after awhile.
Super glue works too
John,
I like your idea with the acetone. Let me know the proportions once you have worked them out. That would make an excellent fill.
Guys, I think TimmyD is in trouble - one of the first signs of the snuff impacting your gell being is that effects your speling.Tim - get outside and breath large quantities of flesh air.
Yes Ric, just loverly.
What are the chances that label was printed in China and TimmyD quoted verbatim??
Eventilation: (n) 1. Feeling of elation brought on by a specific event.
2. The act of letting the air out of an event.
Thank you all–this is a very useful thread. I’ve been experimenting with various glues and I’m not all that happy with any of them, got some laquer thinner to try this afternoon
I love the smell of MEKin the morning…
