Steve wrote: [i]"
G1MRA. B to B 1.654 inches
NMRA. B to B. 1.575 inches"[/i]
Steve, you’re looking at G1MRA’s “fine scale” standards. Look at the “standard gauge 1” standards at the top of that page. Those are what we used. The G1MRA “fine scale” standards are akin to NMRA’s “proto” standards (S-#-1). Incidentally, the b-t-b for that standard is 1.649" for the NMRA’s “Proto:32” standard, and 1.588" for “Proto:20.32n3”. Note that these values are derived directly from the prototype dimensions, thus different values even though the track gauge is the same.
With no offense meant to Steve for looking at the wrong standards (honest mistake), here’s a side-by-side comparison of G1MRA “standard” and NMRA “standard” (S) and “deep flange” (DF) standards. Values represent the total range of acceptable measurements. Where there is no suffix to the NMRA values, they are identical for both sets.
Track:
Gauge:
G1MRA - 1.752" - 1.772"
NMRA - 1.766" - 1.782"
Check gauge:
G1MRA -1.654" - 1.674"
NRMA - 1.648" - 1.662"
Span:
G1MRA - 1.555" maximum (no minimum specified)
NMRA - 1.535" - 1.555"
Flangeway:
G1MRA - 0.100" - 0.120"
NMRA (S) - 0.092" - 0.117"
NMRA (DF) - 0.091" - 0.118"
Wheels:
Back to Back:
G1MRA - 1.574" - 1.594"
NMRA - 1.560" - 1.594"
Check Gauge:
G1MRA - 1.614" - 1.634"
NMRA - 1.619" - 1.648"
Flange depth:
G1MRA - 0.079" maximum
NMRA (S) - 0.066" maximum
NMRA (DF) - 0.118" maximum
Flange width:
G1MRA - 0.040" - 0.060"
NMRA (S) - 0.041" - 0.061"
NMRA (DF) - 0.060" - 0.076"
Wheel width:*
G1MRA - 0.216" - 0.236"
NMRA - 0.236" - 0.271"
*G1MRA wheel widths are based on a prototypical wheel width in 1:32 scale only. NMRA Wheel Width values allow for the manufacturer to produce wheels to a prototypical width in all scales from 1:32 to 1:20.3.
@Greg, I’m curious–I found this on your web site where you commented on the NMRA’s standards a while back (at the time, still in draft proposal form, which I would presume to be one of the drafts I sent you to get your input. Alas, the link is broken, so I don’t know the specific draft.)
“Also, the flange depth is nuts for outdoor use. 2mm deep flanges are tough for almost everyone, 1.68 deep is ludicrous.”
1.68mm flange depth appears to reference S-4.2, the NMRA’s “standard” standard. I agree–that’s a bit small for reliable outdoor use. The 2mm flange depth is G1MRA’s maximum flange depth. In your post above, you describe the G1MRA standard as “workable outdoors,” but your web site describes its flange depth “tough for almost everyone.” If that’s the case, would you not agree that increasing the depth to 3mm might make strides in terms of making it “easier” for almost everyone?
Funny, the crux of this discussion seems to be that standards are moot without manufacturer buy-in. We decided on a 3mm flange depth specifically to foster manufacturer buy-in. The manudacturers told us 2mm was too shallow for their customers. It was a non-starter. What choice did we have but to meet them halfway if we wanted them to consider the standards? Doing so had no impact on the efficacy of what we were proposing.
Concurrent to us working on these standards, certain manufacturers shifted to a more scale wheel profile that happened to meet the standards we were working on. Coincidence? Dunno. We and the manufacturer were both working towards the same goal–better looking wheels that still ran reliably in the garden. Did they copy what we were doing, or what other manufacturers of quality wheels were doing? All I know is that wheels that are manufactured to meet the current NMRA standards now ride under a fair amount of large scale equipment, and they run quite reliably outdoors. It wasn’t just “dumb luck.” Steve mentions Gary Raymond’s wheels as being his preferred wheels. Gary was instrumental in these discussions. His knowledge of all things wheel and track-related was invaluable to writing these standards. I can’t see him allowing a standard to be published to which he wouldn’t manufacture himself.
Bottom line, the NMRA has a somewhat dubious history when it comes to large scale standards. That’s precisely what got me involved in the process. I saw what they were proposing, and opened my mouth a bit too wide. They came back and said “please help us, then.” I accepted, knowing it was going to be a really tough sell in the large scale community, no matter what we came up with. I went on the forums asking for input. What I got in return was anything but constructive. So it doesn’t at all surprise me to still hear reverberations of those early criticisms.
I think we achieved what we set out to do. Those critics are always going to be there. I’ll point to the models on my shelf which meet these new standards whose predecessors do not. I’ll troubleshoot problematic rolling stock or trackwork, confident that if I stick to the standards, I’ll likely solve the problem. It’s not going to silence the critics–nothing ever will. But I know that when I was critical of something and someone said to me, “okay, fix it,” I had the intestinal fortitude to step up to the plate despite the unpopularity and give it my best. If those results fall short of your expectations, grab a set of calipers and have a go yourself. Ain’t a thing in the world stopping you but you.
