Devon Sinsley said:
David Maynard said:
I have a Proxxon mini table saw. I would like to have a larger table saw to make my big wood into smaller wood that the Proxxon could handle better, but I make due, since I do not have the space for a larger table saw.
I have a drill press, and I have a grinding stone that I chuck into it for grinding switch points and such. I also have a home made die to put into it for pressing rivet effects into sheet metal.
What size blades does the proxxon use? I am thinking my rock saw would work well as a mini table saw. It will take the 5" range blades.
As for the drill press as a rivet indenter I like that idea. What do you use for the die. Seems like a rounded punch or even a reworked old drill bit may work. That is a good idea.
The blades on the Proxxon and larger Microlux saws (same saw actually) are 3 and 11/32nds of an inch in diameter. I have cut strip-wood as small as 1/32nd x 1/32nd on the saw. But a zero clearance plate is a necessity.
For my rivet embosser, I ground a rounded punch form into the end of a large nail. For the die part, I use a medium nail set. In the end of the nail set is nice half round concave shape. It makes rather nice looking rivets in soft metal and card-stock.
