Steve,
I flattened the tube first, then bent it. As I had said, it wanted to bow up as I bent it, but not kink really.
Steve,
Wow…that might be the solution to my stirrup step problem as well!
Brian,
Re-reading your howto’s on the ladder frame. You don’t use any heat? You just work the tubing around an Exacto knife handle and it will bend a little upwardinto the third plane and you flatten it with light uniform taps of a hammer.
Wow! Excellant close up detail and instructions. Thanks. Got to try this.
Ric,
You are quite correct. No heat required. Just don’t be impatient and try to bend it all at once.
The caboose looks fantastic…
