So Dan Gilchrist and I have been doing a little conversing about this car. The juices are flowing and I really don’t think it will be a difficult project. I have a depressed center flat car that I will probably never use, so I will use it as the base car for this rocket launcher. I will use a servo and control board to operate the launcher. I will employ some sort of remote switch to operate the servo and another to fire the igniter.
This will be a simple whimsical affair, not trying to even attempt anything close to prototypical. Just good throw it together fun. For the rocket I jumped on Fusion and designed some parts to be printed that will be joined with standard paper tubes. Rocket is small(ish), 20 cm long as designed, but since it uses standard paper tubes the length is customizable. . Will hold a 1/2A motor and be tumble recovery by ejecting the motor. Already ordered the rocket stuff. even if the car never sees the light of day I can still have fun with the rocket.
This little Bluetooth controller would allow me to raise and lower as well as fire the rocket using my smart phone. It would be the switch that then runs the servo control board Dan posted.
