Time for another update
The engine and drive line are completed and mounted in the frame and the front frame cross member completed.
Sorry about the poor picture.
The engine was built up from Redwood blocks, Styrene, wire and brass pieces. The engine mounting in these old Mack’s is kind of interesting. The engine hangs from large steel pins centered front and back and just kind of swings there, the drive line being the only thing that keeps it kind of centered. You can see the front pin (brass rod just behind the black water hose) and the hanger assembly mounted into the frame. Of course 69 horse power at 1400 rpm probably doesn’t produce a lot of movement in an engine of this mass and weight
The water pump/magneto assembly along with the starting crank handle I used from the original kit. Although a scale difference, it is hardly noticeable once installed. The motor and trans/differential have been painted and lightly weathered waiting final assembly for touch up paint and final weathering.
Same stuff, different view although here you can see the steering arm linkage that hooks to the front hub and tie rod assembly.
Thanks for taking a look.
Rick
