Lou Luczu said:
Pete, that’s what was in the Doodlebug? My problem was the motor truck was recessed up into the frame, which is why I could not use FA motor block truck.
Lou,
The two motor/gear axle units I linked are Spoerer’s drives.
This is an FA truck, similar to the one I took out of the Doodlebug, fitted with even larger 33" (41mm) wheels:
The truck in the Doodlebug has a flat grey plate with the pivot hole, and two perimeter holes on each side for the mounting screws. You can see the body holes on my first pic. It is only inside the body by the height of the pivot. With the baggage doors open, you can see right through.
My trailing truck wheels measure 35mm approx (34.75?) so they are 28" prototype wheels?
