Nicolas Teeuwen said:
As a side note, I have removed the springs from all my SD70 couplers, and widened the swing by cutting a notch in the frame so the couplers can swing further. This eliminated issues with the couplers coming undone at certain points on my railroad. The biggest issue i had was with two SD70’s pulling a consist. The front one would often detach and take off leaving the second one to pull everything. I was able to tweak the track geometry in a few places to fix the issues but the connection was unreliable. My conclusion, if pulling SD70’s on 10’ diameter curves, you are best to remove the springs and widen the swing of the coupler for better reliability.
Nicolas,
I am very curious about this as now I wonder if my “prototypical look” mounts will be a problem for some. I assume you are using Kadee “G” scale couplers? Do you know what exactly is happening when the locos detach?
-Dan
