John,
I don’t have much experience with attempting to revive overly discharged batteries or for that matter a “KNOWN” it will be okay voltage reading… 2.5V per cell is typical cut-out voltage recommendations. I have seen cells @ 1.8V or better cycled, load tested that worked with some diminished capacity. How long they lived thereafter I don’t know as they were not my batteries. Since were dealing with NON volatile situations if your power system fails (unlike aircraft) I can see the merit in rolling the dice and utilizing a resurrected battery.
As suggested hammer it for a few minutes or so at 14.0-16.0V/2A and see what happens. DO NOT WALK AWAY AND MONITOR CELL TEMPERATURES. Some suggest all Li-Ion cells are 3.7V whereas most OEM data sheets suggest their 3.6V. Lithium cells don’t need to be fully charged, close is BEST for long life. I’m confident (but not 100% sure) your Tenergy charger has a screen for Li-Ion cells. You’ll note it sees them as 3.6V per cell, use this regimen always! IMO 3.0V-4.2V is safe well established baseline operating range for your 18650 Lithium Ion cells.
If your successful burping the cells (success would be reading about 2.5V + voltage of each cell individually). Use the balance charge regimen to completion, then discharge cycle the battery and recharge for a couple of cycles, again your charger can do this automatically. I wouldn’t be surprised to record a 20% or better loss of capacity.
FWIW: If you were to find a discharge graph for Lithium cells you’d note how steeply voltage falls off the chart, once you realize approximately 3.2V the voltage starts falling nearly straight down within seconds IME. I used Lab equipment (Oscilloscope, PC controlled power supplies and electronic loads) to evaluate these batteries for several years (seems like a lifetime ago) yet I stayed within published safe voltage recommendations when evaluating same. Voltage cut-off @ 3.0V per cell nets about 95% of the cells capacity.
PCB’s are generally rated for cut-out @ 2.5V per cell. (http://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Michael
