I could not respond yesterday to any posts as my other half had eye surgery yesterday. she is doing fine now and we went to the optometrist this morning for a check. She had an two kinds of aggressive growths and only found the start of it 1 year ago. She now has two new eyes with Toric Lens and never has to worry about cataracts again.
HJ: Love your design and can see that being built, my way was going to be expensive with all the track and a major construction job. I know the 3 foot rule cannot be maintained, but the elevation is going to be low so getting into the display should not be a problem.
The trees in the upper left are staggered, total of 5, and I can work around them.
One item that may have to change, because i did not mention it at all, is the trolley line in the upper left. My vision was the mainline loop be on a trestle around the tree. My wife want to plant a lot in that area. The other trees would take some work to prevent them from being killed from covering up the base of the trees. Was thinking of the track on the right being on a slight grade to reduce the elevation on the upper portion.
If this was done with AnyRail, I do have a copy and would like to check it out closer if you don’t mind.
Dennis
