Thanks everyone for the comments on the rockwork. I will pass them along to Youngest Daughter! She is my “crafty one,” in that no material, no matter how plain, is without application to a project. You can imagine what her part of the girls’ bedroom looks like!
Today, Kid-zilla has been my sidekick as we pushed the project to “turn-over,” that point where I am going to have to rely on the crew to bring a good part of this over the line.
First on the agenda was addressing gaps between cross timbers and the cladding. In desperation, I grabbed woodfiller, which Kid-zilla and I applied to the various gaps.
In the ideal world, we would have let this sit for 24 hours, let it cure, sanded everything, and then applied the battens. This is not the ideal world, so the two of us and a bottle of RapidFuse started the process of turning craft sticks into battens.
Copious sanding on the seams, where the warp was most pronounced, allowed a good, level fit.
We also cut and painted the egg crate for the coaling deck after first testing clearances.
He masked and painted Y.D.'s window backs. He needed a bit of help with the spraypaint. It is nice to know I am still needed!
I still had no idea how we were going to mount this deck. I got out the Box of Randon Stuff, and we started going through it. Kid-zill saw picture hangers and eye hooks. Problem solved. We glued and nailed the hangers to the wall…
…and then we glued badly stripped lumber cut last year for a now delayed MOW project to the top.
Though the deck clearly hangs as Kid-zilla demonstrate…
…eventually “chains” will run from eyebolts in that topmost timber (the one clamped in place in the previous picture) to the deck and square it in place. While I am clearly taking advantage of that fact that physics works in my favor in 1:24-ish PLAYMOBIL scale, I think Kid-zilla hit upon a credible solution. As an upshot, it will be easy to remove and repair this if need be.
I started to safe and clean the lanai while Kid-zill fit a timber to the top of the coal receiving area, where an unseen elevator carries the coal to the bins high above.
We added some more battens, but then we had to stop. The lanai becomes very hot at this point in the afternoon, and the all the glues and putties had to dry anyway.
Tomorrow, I hope to add the doors, windows, eyebolts, and falls. Then I can hand-over staining the wood bits, mounting the roof, sealing gaps, making the coal pit, and detailing things out to the crew. I will have them plank over the deck for the coal carts, if I can. It’ll be tight, but I think we may just pull this off!
Have a Great Week!
