Hey guys,
Running a CNC is made every simple these days because of the software available. If you know how to create parts on a mill or lathe and can use Auto-Cad to draw your parts then you have the skills to run a CNC. I have a software program called VCarve Pro. This software allows you to create your parts in 2D or import them from someone else Cad software. Then you assign the tool you want to perform a certain task like cutting a circle or cutting a grove, and then the software creates the “G” code necessary to run the machine. The Mach 3 that Rodney mentioned is what controls your machine and reads the “G” code to perform the task.
It’s so simple that my 23 year old son was up and running parts in less then 8hrs. The software does all the work. When I worked as a machinist over 25 years ago you had to have a programmer on staff to create the “G” code necessary to create your parts, but not anymore.
Of course the software package is not cheap. I paid over 700.00, 5 years ago and still pay 150.00 when a new version is issued about every two years, but its well worth it.
Chuck
