Pull the main rod and eccentrics off. Pull the end blocks (on the engine, one block read and pull the stack, drop out the loop from the front).
I think you have to pull the siderods to clear the valve hanger.
Usually you have to flex a valve gear hanger…some are retained with blocks on the running board you need to remove, drop the block out.
Remove the one screw on the bottom, pull the cylinders up and forward, swinging the valve gear bottom brace down to clear.
Find which side of the block has screws. Look behind the wheels.
Pull those wheels, saving screws and any lockwashers hiden behind them. Retract the brushes and springs so you don’t lose them. Pull the block half towards you off the axles.
There…it’s apart.
That’s from memory.
Probably forgot something.
Pull the motor straight out towards you.
There is probably a ball bearing (single ball) at the end of each end of the motor shaft. Try not to lose them. Internally thrusted replacement mortors don’t need them…original ones do.
Clean all the old grease out. I use lighter fluid, toothbruishes and q-tips. Get the gear teeth and worm clean.
Thed real trick is getting the gears to line up when done.
The reason (for now) you leave the other wheels on is to put the motor in, hold it, rotate around, check the counterweights and crankpins for alignment. Lift the motor, move one tooth at a time and recheck. Insert thrust balls with grease.
When you’ve got the block together, clean the brushes, install along with wheels and siderods.
THEN pull the wheels on the other side for brush cleaning.
