Jim's Whiskey and Easy Short Line
I was concerned about this, but Regner has improved the design to eliminate the need for the flame shield/deflector. There are now only two small holes for the steam and exhaust to pass through the front of the smokebox, there are no other openings in the front which would allow flames to burn up the cylinder springs. That tall vertical slot in your pic where you have the deflector just isn’t there on the new models.
I have had no trouble getting the flame to pop back into the burner, which I read was a point of frustration in earlier iterations. I did have to take the jet out after the first run to reverse blow it for crud that I guess was left over in the tank from manufacturing. Other than that, pretty straightforward for my first runs with this engine.
A very nice feature of this kit is that the brackets to hold the three servos (regulator, reverse, whistle) are included in the standard kit. I’m going to try to get those installed over the weekend.
I haven’t tried pulling anything with the Paul tram yet, but will do so asap once I get the RC done. I need to work on some more custom cars like yours! But here’s the question - would the average Regner geared loco pull the Cape Cod Todd Schnabel? :grin:
Easily, in my experience. Can’t beat 8:1 gears.
I had a Regner Heisler with similar gearing, and added the r/c kit. As it was a slow geared loco I never needed the r/c.
I have the Paul, and it is quite slow too.
Yes, but why bother with that when it should really be pulling a pair of back in the day in the hood Superliners.
:rooster:
Jim;
I wouldn’t expect the average Regner to pull that Schnabel, but Regner’s Heisler just might be able to give it a go.
Yours, David Meashey
P. S. I think my Roundhouse Beyer-Garrett could also pull the Schnabel.
