David Russell said:
Looks awesome Ray!
What did you use for your ceiling crown/cornice molding as it has a good profile. I also noticed it’s inset downward somewhat, is that too support the 2nd floor? Are you going to paint the edge of the plexi on the cabinet doors or are you gonna trim them out(on the very end)?
As for the false door and the curtains…technically they would be called portiere’s and hung as a pair on a rod with brass rings(sorry had to throw that in there but I know you can do it!!)
Thanks! I glued a quarter-round rod into an L-angle to make the ceiling molding. It will be used to help support the ceiling. (There will be a space between the ceiling of the first level, and the floor of the second story.)
Yes, I need to paint the edge of the clear plastic on the cabinet doors.
I’m still debating whether or not I should attempt brass rings for the doorway curtains/portiere, or just do something simpler. Also debating how to make the curtains themselves. I’m not real happy with the curtains I made for the windows of my first building. I may try rolling out some poly clay really thin, and shaping it into the proper folds.
