Here’s a little update….
I covered the roof with corrugated aluminum panels. These were made for me by Dave Taylor. I used Dynaflex 230 to glue them to the roof:
The rear wall of the building is removable for access to the interior:
The interior will be built into this box structure. Like the rest of the building, this was made from Sintra. The ceiling will be added later:
I printed wallpaper and flooring onto self-adhesive vinyl and applied it to the interior structure:
The building’s interior is divided into two sections. The larger section, on the left, will be a radio repair shop. The smaller section will be a barber shop:
I sprayed the building’s exterior with a coat of white primer. After that had dried, I applied concrete colored latex house paint, working it into the mortar lines and cracks:
I painted the aluminum roofing with self-etching primer, followed by Rustoleum’s “Cold Galvanizing Compound” for a realistic galvanized metal look:
On my first brick building, I applied most of the brick-colored latex paint using a flat “stamp” made of scrap pieces of Sintra. This time I tried just dry-brushing it on. That seemed to work just about as well:
Then I used a fine-tipped artist’s brush to touch up individual bricks as needed. I didn’t spend too much time and effort trying to get it perfect, since most of the bricks will eventually be covered with white paint. Here’s how it looks so far:
That’s it for now, more later.
