Time for another update:
I needed a tool to press the mortar lines into the edges of the window openings, so I just took an old #11 blade and ground it flat:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8676c/IMG_8676c.jpg)
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8663c/IMG_8663c.jpg)
I also carved more wear into some of the bricks. The loose brick was created by gluing a thin wedge to the face of the scribed brick:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8706/IMG_8706.jpg)
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8710/IMG_8710.jpg)
The side walls of this building would have been made of cheaper material such as rubble stone, so I scribed stone texture into the upper portion of the walls. To see a step-by-step of this technique, check out my previous build here:
http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1.html
On the east wall, only a small portion of the wall will be visible above the previous building:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8697/IMG_8697.jpg)
My next building will probably be only a single story, so I had to texture a large portion of the west wall of this building:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8730c/IMG_8730c.jpg)
I added stone lintels to the upstairs windows. The thin ones at the bottom of the windows are resin castings. I had hoped to use existing castings for the large ones above the windows, but they were a bit too tall. So I just carved some new ones out of Sintra PVC specifically for this building:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8745/IMG_8745.jpg)
The bottom of the front wall wall is stone, so I glued on some of the resin castings I’d made for my previous building. On the right, the castings have been cut to fit the sloping sidewalk:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8743c/IMG_8743c.jpg)
I also glued some castings to the foundation. Eventually all the “stone” parts of the building will be painted the same sandstone color as the previous building:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8719/IMG_8719.jpg)
The front and side walls were glued together and the subfloor installed. Then I discovered that the foundation is slightly non-square, preventing the building from fitting up tight against the sidewalk. No big deal, I’ll just fill the gap later:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8741/IMG_8741.jpg)
Here’s how it all looks so far, with the building temporarily in position on the layout:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8731c/IMG_8731c.jpg)
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_2_files/Media/IMG_8735c/IMG_8735c.jpg)
That’s all for now, more later. Enjoy!
