Got a lot more done…
I filled in the area above the main arch, cutting some of the stone castings to fit as needed. I also added castings on either side of the upstairs windows:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7848/IMG_7848.jpg)
Between the windows and the attic vents, are stone slabs which are smoother than the other stones. I made these from strips of 1mm PVC. I used a rough rock to give the “slabs” a little texture:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7863c/IMG_7863c.jpg)
The slabs are sandwiched between extra-wide stones. I made these by gluing together three regular stone castings, then using putting to fill the indentation between them. At first I used Squadron White putty, but it was too soft. Later I switched back to using the automotive spot putty:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7874/IMG_7874.jpg)
I shaped some stone castings to fit around the attic vents, once again using a crude drawing as a guide:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7888c/IMG_7888c.jpg)
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7878/IMG_7878.jpg)
After I finished the arches, I added the narrow, vertical stones near the top of the building. Alternating stones are mounted on strips of 3mm PVC. Before these were glued in place, I made sure that all the vertical stones would fit as intended, with a raised stone at the center, and a lower stone at each end. Once the vertical stones were in place, I filled in the remaining area, cutting some of the stone castings as needed to fit around the arches:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7897/IMG_7897.jpg)
The next step was the fancy trim at the top of the building. For part of this trim, I needed a special shape that was built up from two strips of 3mm PVC. The narrower strip was cut at an angle along one side, and then glued to the wider strip:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7906c/IMG_7906c.jpg)
The first “layer” of trim above the vertical stones is a row of thin stone castings. The next layer was done using 1mm PVC, with the same texture as the slabs. I built up the fancy bits at each end and in the center, using short segments of the contoured strip previously assembled:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7908c/IMG_7908c.jpg)
In this closeup you can see some of the texture:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7911c/IMG_7911c.jpg)
The two-piece, contoured strip that was assembled earlier, was smeared with putty and sanded using sandpaper wrapped around a dowel. I also applied the same treatment to the short segments that were already attached to the building:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7916/IMG_7916.jpg)
The last “layer” of trim at the top of the building was made using a .250" x .375" styrene strip as a base. Short sections of 1mm PVC were added to create raised areas:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7921/IMG_7921.jpg)
The top strip was finished with the application of stone castings:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7934/IMG_7934.jpg)
And here’s how it looks so far, nearing completion:
(http://www.raydunakin.com/Site/IRR_Mineral_Ridge_1_files/Media/IMG_7940c/IMG_7940c.jpg)
I still need to make some protruding thingamajigs for the top of the building, at the center and on each end. I also need to work on the quoins on the side of the building, as well as a few other small details. Later, I’ll work on the interior details.
Stay tuned!
