In addition to my 3D modeling I have done some physical modeling. I have the first 1 1/2 layers of the main Hecla building cut out of foam. I ran out of it, dang thing will be huge. But I am using 1" thick pink foam to build up the layers of the main building which will be nothing more than a flat facade against the house. It will be two layers of foam to give the feel of the front of the building. I will get some pictures of it soon.
I have decided to use mostly Roosters technique. I am making it out of foam without any “cladding” I have decided to make it board and batten instead of tongue and groove. I will leave the foam as is and then glue on trim and battens made from styrene or printed details. Heeding Rooster’s comments, with the scale of this building the cost would have been outrageous to use some sort of plastic sheet materiel. So a base of foam then painted and adding styrene and printed details will look good and be coast effective.
